Where to buy C-band Circular LNBF | SatelliteGuys.US
Pixl
Senior Member
1,902
67
Traverse City, Michigan
Yes I know you can shove a piece of fiberglass down most LNBF and get some circular at a loss of signal. I would like to buy one that was designed from the ground up as circular with the little ribs and things they put inside the throat for true circular reception. I've checked many Euro sites where they use this, but no find yet.
Youch! - [TABLE="width: 100%"]
[TR]
[TD]
[/TD]
[TD="colspan: 4"]
[/TD]
[/TR]
[TR]
[TD="width: 100%"]Seavey ESA-44C [/TD]
[/TR]
[/TABLE]
http://catalog.vincor.com/SearchResults.asp?Cat=108
OK Guys, thanks for the reply's. Some interesting hardware but not sure if I want to spring for the high dollar ones. I had better start with a dielectric plate in my older LNBF. Anybody have an extra one? I lost the one that came with my LNBF. There are a couple of sats in the Eastern arc I want to build up a second C-band dish circular for.
The Chap Bullseye II made for circular C-Band uses a dielectric plate glued in the throat.
SKY UK in Turkey, Bodrum area?
Galaxy 19 (97W) Ku-band channel guide -- Sept. 24 update
