Where is AC-3? | SatelliteGuys.US
Where is AC-3?
smata67
118
I see references to PBS on AMC3 having AC-3. Do I just scan it and look under radio? What are the call letters? Any more AC-3 I should know about? THANKS
AC3 means you need a S/PDIF output on your receiver which goes to the corresponding input on your audio system. Usually this is an optical port. Not all FTA receivers have them.
I have the Coolsat 4000 pro, which has the digital coax (SPDIF). My question is, if I hook it up to my new Dolby Digital receiver, what can I get? How many channels? Where are they?
I think there is a goofy way of getting it to work on the 4000. It wasnt a standard feature.
PBS on AMC3 and a couple Spanish channels on G10 are the main ones that need AC-3
The Tube Music Network on AMC-3(C) broadcasts in Dolby Digital 5.1 audio, the G4 Video Game TV channel on AMC-10 is also in DD. I've noticed that sometimes when the FTA receiver says AC3, it is in fact stereo PCM audio and not Dolby Digital...or so my audio amp tells me.
Tony
Home Page - http://www.cyberspace.org/~awh/
Globecast dish pointing
Pictures of my Dishes
