Are you on a custom channel list? Try hitting the "guide" button and go to All Sub or All Channels and then check.
Try menu 6-1-3 and see if any satellites are out. You might have a switch/lnb out.
He's missing 110 where ESPNHD is located.
Hard reset the rcvr.
If that doesn't work you most likely have a bad LNB.
Limited time offer
