Where can you buy a adapter for the ethernet?? | SatelliteGuys.US
Chris36
448
4
Rhode Island
Does anyone know where it's for the 722k HD DVR? Not sure if you can in stores or you have to online?
Need more info. 722 has built in ethernet that can be accessed via the RJ port on the unit or through Powerline which requires a Powerline sender connected to the Internet.
If you want to go wireless you need a WAP - Wireless Access Point. Most wireless routers can be set as WAP. The easiest way to set up a WAP is to get a pair of matching routers. Online they should be in the $20 range. Use your computer to program both the WAP and router. Many say 802.11 G is the fastest speed the 722 can handle.
61.5 being shut off ???
Volume Leveling - Is It Working for Anyone?
