I agree, if you can find the right pipe, use it.
Im too lazy, so I use the 1.8" OD pole that was used for my 1000.2, and then slid a 2" OD 24"L pc of exhaust from the auto parts store over it. Bolted in place, it does just fine and the slimline will tighten right up. Cost about $7, have used it twice and has worked very well.
You will not find a two inch actual diameter pole at Home Depot, Lowe's, Menards, or any plumbing or irrigation supplier. A so called two inch pole is actually 2-3/8 inches.
We use a standard 1-5/8" or 1-1/4 inch nominal pipe with an adapter that a fellow installing contractor of mine developed. If you are using thin wall tubing like a chain link fence line post, it will fit inside of a green farmer's "Tee" post. Either bolt or cement grout the unit together.
My colleague sells the adapter on eBay for a nominal price;
DirecTV AT9/AU9 KA/KU Adapter for old 1-5/8" pole - eBay (item 150277109969 end time Aug-05-08 21:23:38 PDT)
You can definitely find exact 2" OD pipe. I'm a professional installer and my product distributor (Perfect-10) carries it in stock, but it's heavy and therefore very expensive to ship so I pick it up from my local warehouse. Why mess with adapters and all the other nonsense when you can just use the correct pipe and call it done?
Actually a 2" pole is 1 7/8th
And you CAN get by with it, D* installers do it regularly ...
If you want to use your old mast, the product Mike is talking about works well.
The local fence company will have what your looking for.
Jimbo
My dad has purchased parts and is doing a self-install, but the local Lowes/Menards do not have a pole that the dish can mount to. Where does he need to go to get one?
Jimbo - with all due respect - who's talking to you? My comment was directed to Mike500. You can spend $170 or $1.70 on a pipe. Whatever. My point is that two inches is two inches ACTUAL OD, and my supplier is not the only source for this product. Next time I'll quote/reply to be crystal clear.
I found a local fencing contractor, and he sold me a 10' length of (exactly) 2" OD HW galvanized pipe for about $20... forget the thinwall stuff.
I made a mast from it off the side of my deck, I dug a hole about 4.5' deep and filled it with concrete - just make sure and either flatten the end of the pipe or drill through it near the bottom and insert a bolt or a rebar so it won't turn once the concrete sets. I even filled the interior with hydraulic cement once it was set. It's been perfect for a year now.
Limited time offer
