Where are VOD channels? | SatelliteGuys.US
Fuj
13
I plugged in my wireless adapter and it works and I can download movies. However when I go to channel 1000 I see it but I don't see any of the other channels that the setup guide mentioned. ie. 1528 STARZ etc - should I see those channels?
Thanks!
Thanks!
Not unless your receiver is set to All channels,or you have to edit your favorites list, and I had to reset my receiver to see all of them. And you only get VOD for channels you subcribe too. So if you don't have Starz,your not going to see Starz on Demand.
Thanks! I reset my receiver and now I do see them. However when I select any of them it says it's unavailable!!! Now what?? I'm on the plan that gets all the channels.
Lost Signal What are your thoughts
Manual Recordings Moved Up 1 Hour
