Directv only supports splitting 8 ways (one 8 way, three 2 ways, etc.) with no run being longer than 150'. The loss of one splitter is roughly equal to the loss of 50' of RG6 so if you have a short run you can split it more and still be within spec signal wise.
Is there a particular reason you're asking? I'm assuming you've run into some situation where you don't have home runs back to the SWM16 so you need to split at every receiver? If that's the case, and rewiring is not feasible, you can probably do it and remain within spec if you use taps rather than splitters.
