When is... | SatelliteGuys.US
When is...
Scott Greczkowski
Welcome HOME!
Staff member
HERE TO HELP YOU!
Cutting Edge
Sep 7, 2003
103,758
29,593
Newington, CT
When is someone going to make a receiver with a built in Zip Code Database, so you can just take the receiver, plug into your zip code and have USALS automatically setup for your location?
Imaging how easy that would make motorized installs. Move the dish to the satellite you want them move the dish on the pole until you get signal.
Been working on this for years, but the zip/postal code database is very large and consumes far to much flash.
Our new receiver allows the user to select from a list of cities, but the flash is limited to only allow 50 city coordinates. Since USALS accuracy is dependent on exact coordinates, my concern is that this limitation would result in more motor install issues, not less!
If the database was online, this would solve the challenge.
How large a database are we talking?
SuperBuddy costs 5 times as much as an average receiver. I'm sure that feature would add a lot to the cost. And like Brian said, it's not accurate enough for USALS for the most part. Well speaking as a Montanan where Zip Codes cover miles and miles of territory
Currently testing a STB that has GPS. Now, that would be accurate for integrating an auto USALS feature.
Also, once a STB is connected to the internet, anything becomes possible. Suddenly become a few lines of code to query a database... :D
Unimpressed
With the varying sizes of area codes and zip codes, neither sound reliable.
I don't see how burdening a receiver with GPS makes sense, either.
If an uninformed end user is installing, sloppy workmanship is likely a larger source of error.
So, if we educate the newbie in the ways of the plumb pole, he can get accurate coordinates, too.
I only have to find my own once, and write it down.
All MY dishes (and motor experiments) will be at the same place.
Only an installer benefits from carrying a GPS device.
With that being a feature of so many cell phones today, I don't see need for other solutions.
PS: it really would help if the Topic of a thread said what it was about.
I've lost a number of useful discussions 'cause they were confusingly labeled.
I want an HH motor with GPS and auto tracking. :)
Like Ron Popeil said with the showtime "Set it and forgot it"
Id rather just goto dishpointer.com to get my long/lat then pay $50 more for a receiver because it has gps. Its really not that hard.
UDL
Why not have a file online and download it to a thumdrive and stick it in the receiver with the database of zipcodes?
Vertical frequency channels
jynxbox ultra HD v2 turning off and on itself
