Whats wrong with my install? | SatelliteGuys.US
Paradox-SJ
1,636
2
San Jose, California
I had my 921 (replaces a 6000) installed today by DN. They upgraded my lnb's to Dishpro and used a DPP 44 switch. It appeared as if everything was working when they left (about an hour ago) but this was not the case.
The 921 tuner 2 can not lock on to 110 transponders 4,5,6,7,11,13,15,17,31.
All other sats and transponders work fine for both 921 btuners.
I check to make sure that the seperator is connected properly 'input 1 to 1 and input 2 to 2.'
The check switch come out fine seeing all three Sat (110,119.148) and the DPP44 switch.
What could be casuing this? :mad:
THX
Do you have any receivers other than the 921? I've seen stories of people having problems using a Separator on the same port as the power inserter. If you have another receiver try running it to port 1 through the power inserter and put the 921 on one of the other ports.
Dish Please carry the Yule Log on X-mas :)
Why arn't more of you upset about this ?
