what type of lnb | SatelliteGuys.US
what type of lnb
persianoaks
2
Hello,
Please recommend a dual or quad lnb to replace a single lnb which would feed four receives (if recommending dual ,what other gears may be needed?) to work with Galaxy 19 (97 degrees West). Thank you
Iceberg, what about the DMX522, have you had a chance to try it out?
I have had great results using both an Invacom Quad Polar (you would connect the two L outputs to the multiswitch as Iceberg suggests) and also good results using DMSI JSC322, also a dual output and you would also need the multiswitch as well.
Also, the two-output SL2 KU LNBF from SatelliteAV has been well received by the troops, here.
See thread where Linuxman mounted a whole bunch of 'em on a 6' offset dish! - :eek:
Just scroll through and look at the pictures!
And yes you'd need to follow it with a 2x4, 2x8, 3x4, or 3x8 switch, whatever you found available.
See the Switch FAQ for more details, and don't be afraid to ask if it's not clear.
If you were to use a 4x4, 4x8 (no mod necessary) , 5x4, or 5x8 switch, you could actually select between two LNBs... or have expansion room for the future.
where u find a circular c-band lnb??
Digiwave Reciever
