What LNBs do I need? | SatelliteGuys.US
alfaromeo
3
What type of lnbs do I need for 61.5 and 110 or 119? and where to buy them?
Receiver vip222
Thank you.
Is it necessary to have a switch in this configuration? I used to have two 500 dishes pointed at 61.5 and 110/119 and there was no switch between them. The cable from 61.5 with single LNBF ( DP Pro) was connected to the 110/119 dual LNBF ( DP Plus) and then one cable was coming out of DP Plus and went to the receiver. Is this possible to connect everything like that or I am missing something here?
There is a 3(satellite)x2(receiver) switch built into the DPP Twin.
The easiest way to get them is to have DISH Network send someone to install them for you.
Nope your correct. You need a Dish Pro Plus Daul LNB for the dish 500, and a Dish pro plus Single LNB for your 61.5 dish. You plug the 61.5 dish right into the input on the 110,119 LNB and run your 2 wires out . Even if your only using one it will make it a lot easier later if you add another receiver. Then for a 222 you need to run one wire to your location , and you need a Seperator placed at the end of your wire for the 2 Tuners. and your set.
Seperator http://www.dishstore.net/popup_image.php?pID=159
You already have everything you need. I'm a little baffled as to why you asked the question in the first place given that you already knew how it was done.
Dont be baffled, I dont have the LNBs yet, just the receiver, truing to complete the system and was not sure if I need the switch
"Splitter" help....
TR-40 Not for sale in Puerto Rico
