What is USALS???? | SatelliteGuys.US
What is USALS????
gabe33
19
I saw USALS on my motorized setup for my Coolsat 5000. How does this work? I am guessing you type in your coordinates
( Zip Code: 92707
State: California
Latitude: +33.679069
Longitude: -117.876789)
and using this information the motor knows where to go. Is this correct? Is this the method everyone uses to locate their satelites?
So basiaclly I need to find my true south and get a good strong signal, then punch in my coordiantes on USALS and the motor should find other satelites?:confused:
Universal Satellites Automatic Location System (USALS), also known (unofficially) as DiSEqC 1.3, Go X or Go to XX is a satellite motor protocol that automatically creates a list of available satellite positions in a motorised satellite dish setup. It is used in conjuntion with the DiSEqC 1.2 protocol. It was developed by STAB, an Italian motor manufacturer, who still make the majority of USALS compatible motors.
http://www.usals.info/
For the most part, yes. You may not have a true south sat, but you can usually find one pretty close.
Motorized System Level 76% Quality 0%
FTA radio
