digiblur said:FYI... HD, 4:2:2, AC3, etc is all dependent on the PC not the DVB card.
BKP said:Could you expound on this for me..
digiblur said:The card passes the DVB stream to the PC application, whether it be a MPEG2, MPEG4, HD, 4:2:0, 4:2:2, or whatever combination you can come up with the card doesn't care. It's just passing raw data. It's up to you to have the correct software and horsepower to decode the stream.
scottc98 said:IF you can find it...............Skystar 2.3 PCI card!
4.2.2 + HD & Blindscan!
Believe that there is a seperate prog that can move a motor.
Good Luck finding one (no longer made; Rev 2.6D is the latest out)
Limited time offer
