What is on Anik E2R? | SatelliteGuys.US
PilotS77
SatelliteGuys Guru
138
Anyone knows anything about Anik E2R?
I get very stromg quality out of it but no channels!
Interesting I wonder why I have such strong quality around 88%
Which position are you aimed at. Anik E2R is/was Galaxy 3R. When E2 was running low, Telesat leased G3R and put it 111.1 until F2 was launched. G3R is now an orbit spare @74.
So F2 is @111.1, E2 @118.7.
Now I'm just speculating but AMC15 is @113 right now and perhaps it is testing there prior to it's move to it's new home @105 to replace AMC2
charper1 said:
What TP & SR? I would bet big $$ that you are hitting EchoStar7 and DTV7s @ 119.0w which is only .3 deg away.
If it was Echo7, then it would still scan channel data (although incorrect data, I kept getting the same 6-7 channel names over and over last time I scanned them)
Could be - but the dish does move - very iteresting, as I said I get high quality but nothing, I do get the id of the encrypted channels when I go to Echo 7 or any of the Echo sats - and sometimes a card stating "Congrdualtions you have aimed your super dish correctly"
I thought so, you are hitting one of the E* birds. That info card is nice for those of us setting dish positions, by letting you know where you are pointing. Even though thats all I get, I still save the location for a reference point.
What kind of LNB/polarization are you talking about - Ku band with hort/vert polarity or DBS with circular?
I see some responses here that are mixing FSS satellites with DBS satellites in their response to you.
If you are on 121W, then you would see a screen after scanning that says congrats, you have found Superdish 121W or something to that effect..
Rick
I get none of that - and therte is no channel list - when I am an any of the Echo sats I get their channel list.
Phase 3/Trouble hitting 101 on middle
Just an update!
