What is it worth | SatelliteGuys.US
What is it worth
Covack
301
2
Down South
I picked up a 920 4DTV from another installer, I hooked it up, all works but digital.
The unit ID is bad, just wanted some Idea of how much it might be worth without
sending it in for repair/replace board.
Sounds like the ID battery went bad, it's around 200 bucks for a new motherboard/labour to fix that, afaik, that's the only way.
As for it's worth, it's a mostly a paperweight (as analog, the only remaining function, can be done by cheap receivers).
Thanks damaged,
I was just curious, I'll keep it as a backup, if my other 4D goes down or might trade it for a cheap legit fta receiver.
Norsat 8115 lnb
New Transponder
