From Wikipedia said:Dolby E is an audio encoding and decoding technology that allows up to 8.1 channels of audio to be compressed into a digital stream that can be stored on a standard stereo pair of audio tracks.
Anything up to a 5.1 mix can be recorded in 16-bit, however if anything more than 5.1 is requires the tape format must accept 20-bit audio.
It is very important to ensure that a Dolby E stream is never played through monitors without being decoded. The data stream produces a very loud digital noise that can easily blow your tweeters. Tape labeling is essential to avoid this.
What is dolby E audio and how do you decode it?
I have ran across some Fta feeds that have the audio in dolby E.
How do you decode this type audio?
how do you decode it on your pc?Google is your friend:
Dolby Broadcast and Pro Audio Solutions - Broadcast Distribution with Dolby E
For that price i will just look at the feeds.I'm not aware of any PC dvb card that will decode Dolby E. Dolby E decoders cost around $4,000.
I was watching the PGA gollf championship in Tulsa.The HD wildfeed was 4.22 hd dolby E.It was be done by TNT not CBS.Why not just record the CBS HD distribution feed off satellite? I doubt there is any difference in video quality between the satellite backhaul and distribution feeds.
Sorry, I was responding to vfrjim's suggestion which dealt with CBS Dolby E feeds. Tonight I compared the CBS HD backhaul and the CBS HD distribution feed for the football game and both were running at around 38 Mbps.
The golf will be on both TNT and CBS on Saturday and Sunday.
~38 Mbps v. 18 Mbps , definitely a difference
for no gain in video quality.
I'm in total agreement with you that the CBS HD satellite feeds have much better video than the local CBS HD OTA broadcasts. All I'm pointing out is that there is no need for a Dolby E decoder. You can get the best video quality with AC3 audio by recording the CBS HD satellite distribution feed.
CBS HD backhaul satellite feed: 38 Mbps video with Dobly E audio
CBS HD distribution satellite feed: 38 Mbps video with AC3 audio
Local CBS HD OTA broadcast: 18 Mbps video with AC3 audio
Typically if dolby E is in the mux, PCM usually is available, but that is about it. Then you use your AV receiver and create your own Dolby Surround.
Dolby E looks like a LPCM stream to most software and equipment as the software and equipment cannot recognize it as Dolby E since it doesn't know how to deal with it. That's why software and some receivers identify it as PCM. Anyway, sending this "PCM" to your AV receiver, is not going to get you sound, or at least not the sound you want to hear, that is unless you've got a very special "AV receiver" that cost around $4k or more.
Limited time offer
