What is DISH Network channel 9945? | SatelliteGuys.US
It is an information channel.
It is a channel that airs Welcome to DISH Network and DVR and Dual Tuner Made Easy. How to get to it: First, you must have a DVR. Next, go to themes and search and search Welcome to dish or Dvr and dual tun. Then create a record or auto tune timer for a scheduled time. Last, you can go to Options, choose the options like Start Early, Set as System Default, etc., then if you are done with options, select Done and select Create Timer. And when the timer starts, it will take you to channel 9945.
Tony T can you private message me
Need help with unusual remote configuration for 722
