What Happened to Audio Channels 923-981? No Sound. | SatelliteGuys.US
Race
47
I'm not getting any audio from channels 923-981. (I'm on the Eastern Arc.)
The only satellites I'm pointing to, is 61.5, 72.7, 77 (and I don't know if 77 is active for the Atlanta market, yet or not.)
It's affecting both receivers. They're still on the guide, it shows what's playing on the channel, but no audio.
Anyone know what's going on? Is anyone else having a problem?
Thanks.
gary,
Well, how about that? Doing a hard reset worked. I had done a check switch and that didn't work.
Thanks for your suggestion! Problem solved.
VIP 312 Receiver / Signal Strength
622 and Dish 1000
