I hope they did not drop this fine PBS station out of Portales unless is weather realated.
I am in Albuquerque TV market DMA.
If you already have a PBS in Albuquerque I dont think there can be another "intruding" (sort of to say) OTA...at least in the actual city (not the fringes)
in the Minneapolis market there are TECHNICALLY 4 PBS stations that could be on satellite. 2 are carried, 1 needs to find a way to get a signal to Minneapolis (some 130 miles away) and the other dropped its option (Wisconsin PBS station...part of the Minneapolis market is western WI). On cable in a lot of areas you only get 1 PBS
This is where satellite has the advantage
What an irony.
This station is technically - well, actually - owned by the State Of New Mexico and Neilson puts it in a Texas DMA.
They have 10 translator stations in eastern and southeastern New Mexico yet can't be seen on satellite in most of that area.
Their transmitter happens to be in Roosevelt county, between Clovis and Portales which technically puts it on the Amarillo DMA, but where is the common sense here.
I actually live in the Boston area, a little north. There's an agreement between WGBH and WENH. On cable, in MA you only get WGBH and WGBX and in NH you get WENH and one of its subchannels (NH Explore). But for Sat providers, you get all the main channels. I have OTA with my receiver and get all the subchannels as well. Fios customers in this area also get PBS from Rhode Island as well.Same here. The Burlington VT DMA contains VT PBS, Mtn. Lake PBS (Adirondack region of upstate NY), and NH PBS. WLED Littleton, NH is in the Burlington VT DMA so satellite carries all 3 (Dish carries it in HD, Directv doesn't.). Cable gives you 1 or 2 depending on where you live. I am "moved" to Boston and get all 3 I am "supposed" to have (including WENH NH PBS in HD) and WGBH and WGBX.
The OP's PBS is right in AlbuquerqueTo the OP, and actually for Iceberg who's the Directv master around here, what is the nearest PBS affiliate? Coming from my area, I've never heard of PBS stations complaining of affiliates from surrounding communities coming in.
since they look almost identical (both stations direct to the same website) they only need to carry one of themKNME-DT and KNMD-DT's tx are on Sandia Crest mountain. But KNMD-DT is not on Directv at this time....
We have a KUPT in Az. Not sure if the same, but if it is, it was a nice lil "Homsie" channel for a softer viewing. Lots of replays.Strangely, they added a new channel station called KUPT-LD Directv ch. 29 rf ch. 16.1 "Movies!" It's the station out of Hobbs, NM?![]()
Limited time offer
