What could possibly go wrong? | SatelliteGuys.US
tsummerall
45
Okay, I ordered the SD to HD upgrade.
What do I need to watch out for when the installer comes? My worry is that my location won't be able to see all the sats necessary for all the HD channels.
Is it all or nothing or is there a sort of half-assed half the HD channels install?
What sats are you getting now? If you're on western arc (119 & 110), then 129 is slightly right and a little lower than those.
A couple thoughts
connect multiple receivers
