Quite a bit, actually, and there are plenty of old Dish500s to be scrounged very cheap or free.
My testing indicates that any Ku band linear signal with an EIRP of 48 or above can be tuned in reliably with this setup. Incidentally, that agrees with the recommended dish sizes for different EIRPs at Lyngsat maps.
In the real world that means here in Rural North Central Idaho, I get the following results with a Coosat 6000 and six feet of RG-6. The LNB is a cheap .3 rated "ROC" brand from eBay.
Weather was moderate overcast cloud cover.
The EIRP figures are from Lyngsat maps.
Galaxy 28 @ 89w EIRP 48/49. ABC Newsnow tp 11953V s/r19549 - 70% Q
Note: I am using this setup through a SW21, a CHIETA 4x1 DISEQC switch, and 125 feet of RG-6 to get ABC NEWSNOW on our primary FTA satellite TV setup. Quality varies from 50% to 95% on CNX Mini, depending on time of day and weather conditions.
Galaxy 19 @ 97w EIRP 48. Most transponders are 63- 69% Q. Peaked dish on AlJazeera TP 12152H s/r 20000
AMC4 @ 101w EIRP 50. All FTA channels watchable. 65- 70% Q.
AMC21 @ 125W EIRP 47 Could not lock any transponder. Caught flickers of signal, that's all.
I used a cheap LNB holder from eBay and extended the LNB arm on the dish with a piece of aluminum screwed in place. Steel or even wood would work here, and the universal mount LNB holder made it a simple project. I have another Dish500 that I converted to single linear using welded steel for a new LNB holder bracket, but that was not so simple.
Close up of LNB mount.
Simple wood jig to position new LNB. Build it to fit right between the old twin circular LNBs, then align the new one with it. I used a pencil to index it to the dish. Pencil marks are not visible in this photo.
