What button would it be? | SatelliteGuys.US
Most(if not all) stand alone dvd players don't have a way to change audio, it is all handled through your TV or Stereo.
What are you using for your sound? Your tv's built in speakers or your stereo?
If its your tv then your set if you have the remote programed or your tv.
My guess is that you are using your stereo. In that case yes it can be done on most
but not all stereos.
On your DISH remote you will use VCR or AUX to control your DVD player. Find the code that operates your DVD then start pushing buttons if one operates the function you want you have your answer. Most likely you won't find a button that serves that function.
These remotes aren't made to do EVERY function on hundreds of DVD players,and TV's. Its a Dishnetwork remote. Its main function is operate you receiver and Volume and Power on your TV. The fact it has additional feature for DVD players is a bonus.
sound dropping out on espn2 hd
Flyers/Senators on NHL CI
