Weird problem. | SatelliteGuys.US
Weird problem.
bobsav2001
155
13
St rémi Québec Canada
Stb AzBoxminiMe 4 sats 87W-91W-97W-107.3W all KU band and all are working fine.
S2 on 87W and 4.2.2 on 107.3 are fine.
Problem is SES2 87W all channels are ok but The Patient ch.
It will take 30 seconds for the quality bar to come on.
Signal at 70 quality at 86 but no video no audio.
This ch came on only about 5 times in 2 weeks with good picture and sound.
I know it is a low SR but Katel (Telemundo) is even lower and ok.
Patient ch is perfect on my cheap Ariza stb.
Any one with a miniMe noticed that issue?
Thanks Bob....
I can't provide a lot of knowledge here, but when I've had stations with a good signal but with blank screens/audio I have just rescanned the transponder and it comes in just fine. Have you tried this yet? (microHD here, not miniMe)
Just read this and I see you found it...but I was gonna say something is drifting in Freq. some where.
My Azbox & Titanium PLL LNBF says 11801 H 2686 and comes in around 90%Q on the 90cm dish/motor. Keep in mind I am using an Ultra not a mini-me, might be different hardware and certainly different software. Tunes in instantly when switching to the Patient Channel from any other TP on that sat in my list.
Will do a re-scan just for fun...
edit:
scans in same as before. Check your FEC, mine shows 7/8. If it is set to "auto" it might take extra time for the receiver to find...
"Here's Lucy" joins COZI lineup
121w oddities
