I was going to give you a really smart-alec response like "RTFM." But I read it and it is NOT THERE!
So I pulled one of mine 721's out...answer 65w.
BTW, if you are going to connect a modern TV remember that when you first turn most of them on, they go thru a degauss cycle that peaks the startup current. The setup I had before would not start properly on a 500va UPS (Belkin) after the battery aged a year or so...thus the overrated APC (above).
I hope this helps.
