Waterproof SWM8 Box | SatelliteGuys.US
Waterproof SWM8 Box
petsheep
69
Chicago
Long story short... my Slimline used to be mounted on my balcony and I've moved it to the roof using a non penetrating roof mount. I used to have my SWM box covered on my balcony so rain and snow could not get on it. Now that the box is on the roof, I'm afraid that water will damage the box. I put a plastic membrane around to box for now, but I want a more permanent solution. Do I even have to do this? Am I over paranoid? Anyone run into this issue? I'm sure I can figure something out, but I'm just looking for some suggestions or ideas from the forum.
Thanks!
Thanks!
If they have rubber grommets on the ports then there's nothing to worry about but putting it in a box wouldn't hurt.
Newbie with some installations questions.
Newb needs help with install can't get sat 99
