Wanting to upgrade from hopper 2 to hopper 3 | SatelliteGuys.US
kpip99
344
5
I have 2 external hard drives on my hopper 2. Will all those recordings still be there if I upgrade to a hopper 3? Is there any way to transfer my timers from hopper 2 to hopper 3? Thanks
And yes, the H3 will read EHDs recorded from the HWS. You might need to give it a day or two.
Reactions: JSheridan
The external hard drives connected to a Hopper receiver are tied to your account and will work on your Hopper3. The exception would be a Hard drive connected to a non-DVR recorder since it is formatted differently.
your timers are backed up to your remote weekly.
Even with this remote ?
While it does automatically back-up Timers and Preferences, it is a good idea to perform the update manually by going to the menus and finding the feature to manually update using the remote just before you switch out your Hoppers.
Dish Alignment?
vip612 internal hard drive replacement
