Wanting to Add 118.7 and 77 West to set up. What's the best way? | SatelliteGuys.US
Conway
254
206
Here is my set up.. I am on the Eastern Arc with a DPH42 switch for 2 hoppers. What is the best way to incorporate 118.7 West and 77 West to the set up. Thanks.
Wow, first, you'd need an Eastern Arc DPP 1000.4 Dish and LNBF and a 1000+ Dish/DP 500 LNBF. Has to be a DP not a DPP pointing at the 118.
Then you'd run three cables from the 1000.4 LNB to the 42 switch, ports 1,2,3 out to ports 1,2,4 in and 1 cable from the left output on the DP500 LNB to port 3 in on the switch
Need help identifying 129 satellite
Swapping rooms with a Dish 52.0 remote and a 54.0
