Want four satellite locations. | SatelliteGuys.US
jergenf
378
Would like to include 61.5 to my SuperDish (4 satellite locations).
I have SuperDish (110,119,121) with a DPP34 switch connected to my DVR921.
Would like to add a separate 18 dish (which I still have) for 61.5. Presently my spare LNBs are legacy but I understand they wouldn't work with the DishPro plus series that my SuperDish has. So I expect I'll have to buy a dishpro LNB. I'm hoping to avoid buying the DPP44 because it cost $200. Is there a cheaper (less than $100) alternative? I still have two SW21 switches if they're of any use.
There's a thread by the "mad scientist" that was able to do 5 orbitals without the DPP44, lemme look...
The DP21 will work with the DP34 or DPP44 and a Single/Dual LNBF.
The DP34/DPP44 MUST be on DP21 input port #1.
This is a good solution if you only need the fourth bird on one or two boxes.
So I'll need to buy a DP21 switch and a DishPro single LNB. Then connect the 61.5 dish to the DP21 which connects to #1 input of the DP34. Obviously the cable already connected to #1 would be moved to the other input of the DP21 as well.
And when using the DP+44, don't put the DP21 between the power inserter and the DP+44 or you will fry the DP21.
Correct. The power inserter must be:
  • on output port #1 of the DPP44
  • closer to the switch than ANY other device except a special high-current diplexer
Self-installation
921 Card Swap Issues
