Is the Wally DVR compatible? I'm trying to add DVR functionality without having to upgrade to the hopper and joeys etc.
Yes, you need to buy a compatible USB hard drive and it can act as a DVR.Is the Wally DVR compatible? I'm trying to add DVR functionality without having to upgrade to the hopper and joeys etc.
How does dish activate this feature once I hook up a compatable hardrive?Yes, you need to buy a compatible USB hard drive and it can act as a DVR.
The quick guide to adding DVR service to your Wally
One of the neat things about DISH hardware is its flexibility. For well over a decade, DISH has had the ability to add external hard drives to their receivers, turning them into single-tuner DVRs. While one tuner may not give you all the recording capabilities you need, it can be perfect for a...www.satelliteguys.us
You make a phone call and request activation and they send a hit to your Wally.How does dish activate this feature once I hook up a compatable hardrive?
I've got more than 1 Wally how will they know which oneYou make a phone call and request activation and they send a hit to your Wally.
It's the whole account last I rememberI've got more than 1 Wally how will they know which one
You should probably add this only works connected to a proper LNB &/or switch configuration. I know it works with the DPH (hybrid) line, but doesn't it work with certain others, like the DPP LNB/switches?With the hard drive connected you have access to 2 satellite tuners so you can record one thing and watch something different at the same time or record two things at the same time.
Can't you do sneakernet by moving the EHD from one wally to another and see the programs recorded there by the other Wally? It works that way with the 211 series. WAAAY back when I had a 622 and two 211s with 3 or 4 EHDs for my 211s and could shut one down (important) and move the EHD to another (also shut down - unplugged from power) power it up and the programs were there to play.
Dpp provides signal up to two tuners per line and hybrid lnbs or switches up 16 tuners per line. So it works with any configuration.You should probably add this only works connected to a proper LNB &/or switch configuration. I know it works with the DPH (hybrid) line, but doesn't it work with certain others, like the DPP LNB/switches?
Limited time offer
