Does the Wally support Dish Anywhere? Thinking about swapping out my 211k with a Wally, since the 211k doesn't support Dish Anywhere.
https://www.mydish.com/dish-anywhereDoes the Wally support Dish Anywhere? Thinking about swapping out my 211k with a Wally, since the 211k doesn't support Dish Anywhere.
So Sling Loaded broadband Connected DVR wasn't informational enough for you?Not sure how that link is helpful. I can't find a reference to supported receivers there. A simple "Yes" or "No" would have sufficed.
A Wally isn't a Sling Loaded DVR...
You need Sling for DishAnywhere. Neither the 211s or Wally has Sling. I'd say the answer is no.
Gee whiz, I thought this was a "helpful" forum. You're just a jerk.
Gee whiz, I thought I was being helpful. I not only answered the question with a no answer but also gave the reason why.![]()
Ah, now I understand. I don't see his messages!Not you, Troch77.
Seems obvious that you a little something about Sling.How is somebody supposed to know which receivers are "sling loaded" anymore? I'm new to the Wally. I didn't know if it was or not. So once again, the link was not helpful to me. I'm leaving it at that.
Just a simple Google search would have answered your question.That doesn't mean I know whether a Wally has Sling. HENCE WHY I ASKED THE QUESTION. What is your problem?
Well there you go.Actually, comfortably_numb, the answer is, "YES", the Wally does support Dish Anywhere. All you need is a working broadband connection to your Wally, and the app. You can -
View your prg guide and channel lists, including any ota
Create, edit, and delete your auto tune timers
Use your smartphone or tablet as a virtual remote
Create, edit, and delete your dvr's timers and programs (with a connected external hard drive)
Sent from my SM-G920V using the SatelliteGuys app!
Yes, it does work with that but you can't watch any programming off the Wally, even a Wally with an EHD....Actually, comfortably_numb, the answer is, "YES", the Wally does support Dish Anywhere. All you need is a working broadband connection to your Wally, and the app. You can -
I knew that, But I definitely wasn't going to say it.Yes, it does work with that but you can't watch any programming off the Wally, even a Wally with an EHD....
Limited time offer
