VU90xr | SatelliteGuys.US
VU90xr
wmj5
27
I just bought the vu-90xr antenna from radio shack and put it on the chimney,I have the H20 receiver with directv,I didn't gain but very little from rabbitears. wmj5@aol.com Jerry Johnson
Digital reception
Digital reception can be obtain with the old FM wire antennas that come with the stereo receivers. They are less noticeable than rabbit ears. Unless you have weak signal, roof antennas are a waste of money but, if you need one anyway, cheap TV antennas usually will do just fine. Digital is much easier than analog to receive.
RJ-1000ASTC An inexpensive box for OTA and Cable QAM
Strong Signal but no lock
