[VOOM] remote control | SatelliteGuys.US
P
peteslife
Guest
does anyone know how to program the voom remote control for a
samsung 50" DLP, i keep tryin to program it but it turns the tv off
but thats it.
using the auto program it just skips by the code.
it does not turn on a step two, i think it passes the
code
or its the wrong code
--- satguys2004@yahoo.com wrote:
> http://www.voom.com/use_it/product_guides.shtml
> Just in case you haven't seen this.
> I know from experience after turning the tv off it's
> easy to screw up
> step two in turning the set back on and thus loosing
> the code.
> Although I know the remote is not compatible with my
> GoVideo LCD I
> would think Samsung would definitely work.
> Good luck.
> socalpanman, Posted this message at
> http://www.SatelliteGuys.US
__________________________________
Do you Yahoo!?
Yahoo! Small Business - Try our new resources site!
http://smallbusiness.yahoo.com/resources/
B
[VOOM] (unknown)
G
[VOOM] can't receive messages
