[VOOM] Re: All Voom Channels 720p | SatelliteGuys.US
L
lee_kee_brain
Guest
[VOOM] All Voom Channels 720p
Was wondering why all the voom channels show as 720p.
Had Voom for a little more than a week, Had my HDTV about 3 weeks.
I checked everything I can figure to check, Since I never got a user
manual with the Voom Receiver I'm not sure if everything is set
correctly.
Its connected by DVI to the TV. Is there a setting I'm missing on
the STB?
My PiP only works with a 1028 signal. I wanted to see how it looked.
thanks
Look in front of the STB for the "Motorola" logo. This is a little fold down door. Open it and you see a little red button. Push and hold this button until this orange line lights up above it. (They look like they are built into the receiver) Push and release the red button until the TOP line on the box lights up. That's the one that is 1028p.
Don't hold the red button very long or it will reset the box. Just push it and let go. Like it was said before. The top line is 1080i. If all are lit then each channel will be shown in it's native res.
push
all
> Couch Patato
> This message was posted via http://www.satelliteguys.us by Couch
Patato Thanks What should i set a SD TV too?
Just
> push
If
> all
> > Couch Patato
> Patato
Re: [VOOM] All Voom Channels 720p
480i. But if you use the composite video outputs ( not the red, blue, and
green) component video outputs it is automatic. Same for the S-video
output. Everything but the DVI and the Component video outputs will be in
SD at 480i. You don't have to set anything if you are using a VOOM STB on SD
TV. Just the composite or s video connections.
But you really need to get HD to fully enjoy VOOM. But you knew that.
----- Original Message -----
To: <VOOM@yahoogroups.com>
Sent: Monday, January 17, 2005 11:05 AM
Subject: Re: [VOOM] All Voom Channels 720p
> What should a SD TV be set too?
> Plywodstatebum
> This message was posted via http://www.satelliteguys.us by Plywodstatebum
> Yahoo! Groups Links
And the reason you keep reposting this, "lee_kee_brain" is...?
Still watching HDTV in very heavy rain (no rain fade yet) in Seattle, Gill
> Just
> > push
> If
> > all
> > > Couch Patato
> > Patato
The user guide at the Voom site doesn't make any mention of setting output resolutuions - it is a very simple manual with really minimal useful information.
Whipster56
This message was posted via http://www.satelliteguys.us by Whipster56
Couch Patato
This message was posted via http://www.satelliteguys.us by Couch Patato
Plywodstatebum
useful information.
HofstraJet
This message was posted via http://www.satelliteguys.us by HofstraJet
you can also set the resolution using the remote. i think it's in the
installer set up.
snaggerbob
This message was posted via http://www.satelliteguys.us by snaggerbob
B
RE: [VOOM] Facts and Speculation
M
[VOOM] Help AVS
