[VOOM/DISH/OTA] Got Voom bix from eBay, won't get locals on scan | SatelliteGuys.US
R
rauls4
Guest
Signal strength is good but cannot watch any of the channels.
When I run the Scan Local Channels none is listed.
Item 5 (Activate Box) is unchecked.
Seller said in listing:
"I HAVE VERIFIED ALL HDTV OFF AIR CHANNELS ARE RECEIVED."
How is this possible?
Any help is greatly appreciated.
Raul
Yahoo! Groups Links
<*> To visit your group on the web, go to:
http://groups.yahoo.com/group/VOOM/
<*> To unsubscribe from this group, send an email to:
VOOM-unsubscribe@yahoogroups.com
<*> Your use of Yahoo! Groups is subject to:
http://docs.yahoo.com/info/terms/
Did you try to aim the off-air antenna?
--Dave
> Raul
> YAHOO! GROUPS LINKS
> ▪  Visit your group "VOOM" on the web.
> ▪  To unsubscribe from this group, send an email to:
> ▪  Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> Service.
[Non-text portions of this message have been removed]
Yahoo! Groups Links
Do a soft reset, press "power" buttom on receiver for about 5 seconds, you'll see orange light blinks off; see what happens. Don't ever do a system reset (you can find info somewhere over internet, I'll not tell you how to do it), it will set your receiver back to factory setting, the receiver will become "not authorize..." - Item 5 (Activate Box) will become checked again, "checked" means Not-activated Box. (Don't do a system reset; only do a soft reset.)
B
[VOOM/DISH/OTA] VOOM OTA
R
