Anyone ever repaired one of these? If so, where did you get the parts and how much $$ was involved. Reason I ask is I've got two of these that need parts and I was wondering where I might find them.
ill tell you where to find the nylon nuts if you tell me how to get the old nut out of the actuator arm. haha. i have a link somewhere for them. and they arent pricey.
crackt out,.
I just searched McMaster-Carr(mcmaster.com) & they list several size precision acme nuts(if yours is acme) in both bronze & plastic, pages 1093 - 1096. They also have listings for ball screws & nuts, pages 1097-1098.
Hope this helps.![]()
I've got three Widell .875-6 LH 2G Acme tandem taps here that I rescued from being trashed at work. If that is your thread pitch & dia. then send a PM with your mailing address. I'll send you one for the price of postage.Found a couple that "might" work but are at least a half inch shorter than the original, which is 2 inches. The screw is .167 pitch or 6 TPI. The nut appears to be just some kind of black plastic? I've got a friend looking at making some out of brass or nylatron and free would be really nice.
I've got two of these actuators. One was worn out and the one on the 10ft dish now needs to be replaced.
Maybe that other poster will throw me a bone here.![]()
I've got three Widell .875-6 LH 2G Acme tandem taps here that I rescued from being trashed at work. If that is your thread pitch & dia. then send a PM with your mailing address. I'll send you one for the price of postage.![]()
http://www.a1components.com/itemdisplayn.aspx?item=5283
Plenty of load capability with the brass nut! You already have the milling mach. to cut a flat for the tube. Price is very reasonable too. Looks like a winner!FYI, google this.
Sleeve Nut, 3/4 - 6 Right Hand Acme
1.250 diameter, which is right and it's 1.5 inches long, which is .5 short of the plastic one but hey, it's brass! And for the money I might just go this route since two of those would be as cheap or cheaper than a tap.
Limited time offer
