Visionsat Blind Scan Quirk | SatelliteGuys.US
DocRobster
32
Katy, TX
I think it may have been talked about but I want to see if others who do a blind scan with the Visionsat always get their frequencies off by a 1000 MHz. For example I was scanning H2 looking for 4:2:2 feeds and one shows up 11144 with a SR of 3970. Now I know that is too low to enter into my PC DVB system as I know the real frequency is 12144.
Can anyone explain? I am using a Standard LNB @ 10750.
weird...I know the visionsat can be off by a couple (like 11731 instead of 11733) but I havent heard it off by 1000
are you sure the LNB LO is set up for 10750?
Well I just checked and I have the upper and lower set for "universal" and LNB frequency is 9750 - 10750.
Is there a section to change the LO ? I am assuming that if I did have it set correctly to begin with, then I wouldn't get a signal.
any other ideas?
Dish Network switch with FTA
channel master 66021fd multiswitch
