VIP722K Duo DVR recording problem.... | SatelliteGuys.US
wildfire76
2
Illinois
I have a DVR issue. I was able to find the answer on how to change the recording so that TV1 records off of TV1 and not TV2 (that was my primary issue), however now it comes with a secondary problem.
I went into preferences and turned the tv2 recording off and changed it to tv1 however when I go back to my programs that are set to record in the future, they still show tv2 as the one they will be recorded on. I've gone through all the settings in the DVR menus to try to change the options. I've even looked to see about just deleting the whole series and then going back in and reselecting it, but I am unable to find a way to delete future recordings I have set on the DVR.
Is there a way to change them all to record off of TV1 - or a way to delete them all so I can go back in and set them up?
Thanks!
The record plus feature (menu-preferences-record plus) determines where scheduled timers are going to record (TV1 or TV2). If the feature is enabled, timers will default to record on whatever TV is listed (the default is TV2, but it can be changed so they record onto TV1). If the feature is disabled, the shows will record at whatever TV the timer was setup on. Delete the timers then recreate them with your preferred setting and that should do the trick. To delete the timers, press the DVR button 3 times, select timers, then you can delete the ones you want.
Channel FVOD on 222k
