VIP722 & Crestron system | SatelliteGuys.US
caboclipper
59
Hello everybody:
I was wondering if I could install a vip722 together with a crestron system for home automatization.
The normal crestron system that I have seen before install an INFRARED sensor on the front of the satellite receiver, however my question is if this can be done to control output 2 as well, as far as I understand the remote control 2 on any dual receiver is UHF.
Can it be done ?
Maybe change the configuration to be both of them INFRARED, or maybe program the crestron system to understand UHF.
Any ideas ?
Thanks in advance.
Yes you can control TV2 via IR with any universal remote. Your custom integrator needs to buy and install a TV2 IR Conversion Kit from Dish. So let him know ahead of time. But I have to ask why you'd even be using TV2 at all on a high end system?
Thank you Mdajev
The user who wants this is a customer of mine, and has a 120" tv system, with the crestron system he splits this huge tv in 4 and wants to be able to watch 4 different channels at the same time, he does it now during the tests with blue ray players as the additional feeds.
Crazy enough ? He has a lot of money to spend on excentric toys !! I guess I would to the same if I had his kind of money
Cool. I guess you'll need a converter for each DVR, and put all 4 feeds on different addresses.
I came across THIS video of how it works not too long ago. Good luck, and let us know how it turns out.
Consider using 2 211K receivers with hard drives instead of a 722. That SD output maybe disappointing on the big screen, the 211 will give you 2 HD outputs and the hard drive can be up to 1TB.
At 60", SD will be more than a little disappointing when presented alongside an HD image.
4000 channel range
Amazon Gift card help
