VIP722 and VIP222K | SatelliteGuys.US
VIP722 and VIP222K
Gaprofitt
14
Can I run two dual tuner boxes off one dish? I'm fairly certain two cables come off the LNB and go to some sort of switcher in my crawlspace currently. I currently only have two TV's running off the VIP722 but would like to add a VIP222K to the bedroom to have two DVR's and HD on both TV's with dual tuner capability.
Thanks,
Greg
Awesome
Great,
Do I just run direct from the LNB to the receivers or do I need seperators or switches?
Thanks,
Greg
should be an additional line from dish to ground block(if one was installed) then from ground block to seperator on back of receiver. then you just need to run the tv2 line from receiver to tv2 location switch is built in to LNB on dish
FSN Detroit HD feed downconverted to SD?
Universal Sports
