VIP622,how to record 2,watch 1 ? | SatelliteGuys.US
dukiebluedoc
34
13
Cave Creek AZ
Hi all,longtime lurker here, still relative noob,need advice re recording and watching on VIP 622.
I set up some shows to record weekly episodes,then added more shows to record at the same time,since I know I can record 2 from the satellite and 1 from OTA on this receiver.
Tonight I tried to watch show A at 8 PM,at the same time it and show B were set up to record from the sat at that time.The show A timer had been programmed first,then I later added show B,receiver set to dual mode.At 8 pm the dish switched to show B,both red recording lights on,and would not let me switch back to A to watch it. Instead. I had to cancel show B's recording in order to watch A,which continued to record. I was also unable to add show B as a live in progress recording without watching B--when I tried to switch to A I got a message that I had to cancel the live recording of B to do so.
My question is,can I set up 2 simultaneous recording (or 3 if I add OTA) and choose which one to watch live? Tonight the receiver forced me to watch B live if I wanted both A and B to record.
Any help appreciated,this has caused a low level domestic disturbance in my otherwise tranquil household :o
Caroline
If the receiver is set to dual mode, both red lights are on while recording 2 sat channels, then you would not be able to switch to the channel recording on tv2 when you are watching tv1 without canceling the recording on tv1. However, if you switch to single mode you can switch between both recordings without any problem. The only drawback is that both tv1 and tv2 will be showing the same channel at all times in single mode. As mentioned above, I believe you can go to the 'my recordings' screen and watch the show on tv2 as it is recording when in dual mode.
to solve the exact situation you found yourself in:
- put the box in single mode
- press swap on the remote
- put the box in dual mode again
thanks to all for prompt and helpful replies.
I do have a question re technique outlined by Pepper above
"put the box in single mode
- put the box in dual mode again"
do I initiate this just before the recording starts or wait until the recording/program starts and then do the single-swap-back to dual maneuver?
ps
I always wondered what the "swap" button on the 622 remote did:rolleyes:
C
"Moving" with locals OTA
Dish Sexual Orientation Programming Poll
