VIP612 local channels | SatelliteGuys.US
nightowl66
56
11
N.W. Ohio
I get all but the strongest local channel. I hook up the antenna directly to the TV and the signal strength is 100%, but going thru the dish receiver it won't pick it up. The receiver picks up other local channels that don't have as strong a signal.
I've scanned a few times with no luck.
Signal might be too strong, I think the tuner in the 612 is easily susceptible to overloading. I would try an attenuator in line, a splitter between the antenna and 612 would work.
Or just aim the antenna a few degrees off.
Please let us know if any of this helps.
Sent from my iPhone using SatelliteGuys App. For now.
Reactions: pattykay
Nice while it lasted...
2 Wallies on 1 home run
