Vip222k to Dell Computer via Tuner card! Is that possible? | SatelliteGuys.US
glennh73
73
I have a Dell computer 2.4 Quad Core 4 gigs of memory and im looking to connect from the Duo Vip 222K reciever hooked up to our tv , to my computer too.
So using a Tuner Card is that possible and which type would be ok to get?
Just hate to get the wrong one and have to send it back. I dont care to record or anything i just want to watch some tv on my computer.
Thank you!
Thank you!
For SD almost any TV tuner card that has an NTSC tuner will work to view/record the SD output from the 222k. For HD you would need something like the Hauppauge 1212 to view/record the component output from the 222k receiver.
with the tv 2 r/f out put and windows media center yes , recording and replaying to the pc is also possible but burning to disc is no longer supported, the file type is now encrypted
would this work?
[ame="http://www.amazon.com/Hauppauge-1196-HVR-1250-Express-Definition/dp/B0014YFC18/ref=sr_1_1?ie=UTF8&s=electronics&qid=1276810419&sr=8-1"]Amazon.com: Hauppauge 1196 WinTV HVR-1250 PCI Express Hybrid High Definition TV?@@AMEPARAM@@http://ecx.images-amazon.com/images/I/41k23kWu5xL.@@AMEPARAM@@41k23kWu5xL[/ame]
ACUTRAC III & DISH 500
Colours TV (9407) Gone??
