VIP222 compatibility questions | SatelliteGuys.US
jerzstyle00
67
dallas,tx
Looking to hook up sub VIP222k. Currently have following set-up on roof:
2 direct tv dishes with 3 legacy lnb's(110/119 and 118) going to 4x1 disqec switch.
1)is the VIP222 compatibile with both legacy lnb's and the 4x1 disecq switch?
2)If not compatible with disqec switch can it be replaced with a sw21 or a DP34?
3) If not compatible with lnb can legacy lnb be replaced with 119/118 LNB and be compatible with disqec switch?
4) Or will I need to switch out both disqc switch and legacy lnb with a 500+ dish instead using a DP33 or DP34?
Im looking for the most conservative way possible to make this work .Thanks
How many times are you going to ask this same question? This is not CSR roulette you don't keep asking till you get the answer you want.
LOL Not at all man its just I lost track of one of my threads as I forgot to subscribe to it.But thanks to Iceberg its been found.Would be nice if threads can be automaticallly saved when the OP starts a thread but hey no complaints here just a suggestion to the forum we all love.
2 Dishes, cable maintenance and DHPP
Dish equipment charge
