VIP211z & USB OTA Module | SatelliteGuys.US
yes it does,211z has usb ports
But does it have the software to decode OTA? ;)
Edit, now that I look at it, it seems the I found one place that says that the USB OTA module will work on a 211Z. I can't find a manual for the 211Z so I am unsure....
Edit 2: DishDepot says the dongle will work with the 211Z!
USB Digital OTA Tuner
Connect your receiver to your Over-The-Air (OTA) antenna to integrate your free OTA channels into your DISH TV guide. Adds an extra OTA digital tuner to your satellite receiver so you can record an additional live HD programs at the same time as your other programs!Requires an OTA antenna
Compatible receiver models: 211z
$30.00
I have a 211Z and this shows up in the myDish store.
When I go to Dish store, it only lists Hopper w/Sling as compatible receiver...but maybe that's because I have one.
Dish Depot @ http://www.dishdepot.com/dish_receivers.jsp has this posted:
The all new HD ViP 211z Receiver has arrived, sleek, compact, great for RVing! View HD and SD DISH programming, supports 480i, 480p, 720p, 1080i and 1080p resolutions. Universal 4 Component IR Remote, HDMI and RCA outputs only. 2 USB ports for connecting and external hard drive for optional DVR service or add the OTA Dongle (compatible with 211z and Hopper only) for viewing over-the-air broadcasts.
Does your 211z have an optical output?
I scanned a few pages from my VIP211Z User's Guide, showing the back panel and pages related to the USB OTA tuner.
Unlisted previews?
External Hard Drive Icons Issue
