My first thought was the HD was the problem but I can still pause and continue from that point which leads me to believe that the problem may be elsewhere. Any suggestions?
Unplug the 211K then plug it back in and let it reboot hopefully in a half hour it will have rebooted.My first thought was the HD was the problem but I can still pause and continue from that point which leads me to believe that the problem may be elsewhere. Any suggestions?
Only when recording.
Re-point your dish if you can or have a tech come out and do itHow do I correct it?
OK, well that depends on which Satellite and which transponder you're looking at. If it's western arc, I use Transponder 21 on the Check Switch Screen, you want the 110 and 119 in the 70's, 129 in the high 50's. Being in Cali, they could be higherI finally found my signal strength; 59. What should it be?
Also in California, on transponder 21: 110=72, 119=75, 129=46. They've been that way forever and I get no rain fade. Well, let's say little to none, I had a 10 second fade the other day when it was pouring outside. That's the first one I've had in many years.OK, well that depends on which Satellite and which transponder you're looking at. If it's western arc, I use Transponder 21 on the Check Switch Screen, you want the 110 and 119 in the 70's, 129 in the high 50's. Being in Cali, they could be higher
Limited time offer
