VIP211 no sound with OTA | SatelliteGuys.US
TRSmudge
164
Rhinelander, Wi
I have a good OTA digital signal(65-70), one is SD and one is HD.
But for some reason I do not get any audio with these 2 channels but get great sound with all the Dish channels.
Never had this problem with the 811, but do with the 211.
I am running a optical audio line from the 211 to my Yamaha receiver.
Am I just doing something stupid or is this a problem with the 211?
Thanks,
TRSmudge
211 ota sound
I have this occurrence also. I have to reboot the 211 then I get the sound. I believe that this is one of the problems with the 211. I usually have to reboot about 2-3 a week.
I'm not getting audio from the HDMI port right now, any channel on the dish box. OTA to my TV works, not not via the box.
I tried resetting by holding the button down till it rebooted, but still nothing. I'm going to try a hard reset (remove the plug) and see if that fixes it, otherwise I guess I'm calling Dish.
HD Locals in 4x3 aspect
Ota Hd Johnstown/altoona Pa Antenna With 622
