VIP 722k hard drive for a VIP 211k | SatelliteGuys.US
If you mean an EHD you are using with an 722k...NO. 211K software is incompatible. Not interchangeable. You will need another drive, and pay a one time $40 activation charge.
I actually bought the 722k but can't use cause its leased in someone else's name, so I took the hard drive out and was hoping I could use it somehow, but if I can't use it in the 211k, what kind of hard drive do u recommend
211k does not use internal hard drive. You can however take the one from the 722 put in an external enclosure and use it on the 211k. As KAB stated above you will need to pay the onetime $40 to enable the EHD feature on the 211k. At that point when you connect the drive that was from the 722 which you have put in an enclosure you will be given the option to format the drive and use it for recording.
Dual Tuner 4 Black Bars
NFL RedZone Free Preview This Year?
