VIP 722 Newbie Remote question | SatelliteGuys.US
fharris770
33
Georgia
New to the 722 equipment but lots of experience with a 508 and 510. I just upgraded to the 722. Finally up an running fine after one no show install and the second installer knowing less than me about the equipment and not a clue how to interface with my home distribution wiring. But I managed to get it all hooked up fine myself after he left.
I purchased a second "set" of remotes off E-Bay. One is the 5.3 IR remote (TV 1) with Green chip that does not come out and is not reversible - Green #1 not Black #1) and the other is the 6.3 IR/UHF PRO remote (TV2 ) with Blue chip and can reverse to Black Chip. These remotes are identical to the remotes that came with my 722 and they both function fine at present.
I am running in DUAL mode and have several TV's thoroughout the house that I view with the coax output inabled for both TV 1 and TV 2 using two different "cable" channels so I can simply toggle between the two tuners any time I want.
Now I want to be able to control TV 1 with the second TV 2 remote (Blue chip with Black 2 reversable to Black chip that is just labeled UHF). Is this possible. I sent Dish tech support e-mails twice regarding the procedure and got two different responses, neither of which seem to work.
I see lots of threads regarding this process, but I am somewhat confused by the differing advice on the "chips" ie: Green with green1, green with black1, Black. Any clarification would be helpful.
Also, if I am successful changing TV1 tuner to UHF will the old Green IR remote still control TV 1 when in the same room?
Thanks in advance for any advice. I already see much better feedback here than you can get from DISH tech support.
Call Dish and purchase the new 2.0 remote, $20.00 Will do what you want and a lot more, since it is a learning remote.
Thanks for info, but...
Thanks for the info on the new remote. I may well do that, but, since I have a "spare" blue chip #2 remote I am still interested in converting it and TV1 to UHF.
I read somewhere in the forum that what is needed is a Green Chip with a Black #1. Will this do the trick for my spare remote? If so, will Dish Network give or sell me just the corrrect chip?
Thanks.
Cleaning up program guide
Problems in dual tuner setup??
