VIP 622 Guide Malfunction | SatelliteGuys.US
tempVAdish
709
Temperanceville, VA
Greetings all. I have arrived at my first problem w/ my 622 since installing it in March. The guide is showing "no info available" except for the current hour block. This does continually change. For instance: it is 7:55 now & the 7:30 to 8:00 block shows guide info & 9:00 on does not. As soon as 9:00 gets here, that block (either 1/2 hr or hr, depending on the shows) fills in. This started yesterday @ about 1PM and I rebooted (just holding the pwr button) but it didn't fix it. I also left it off all night but it is still doing the same thing. Also, if it shows info for a 8:30 show & I'm watching an 8:00 show, I cannot hit select on the 8:30 show to set a timer.
I have software version L405
Anyone know of a way I can force a guide download?
Thank you,
Rob
Ah, will do that right now. Will post update after.
Thanks,
Rob
Update: It works! Thanks so much for the help, I just did the power button reboot on it because my old 311's go through the guide download after that. Anyways, thanks again for helping me get back in business.
Rob
Dish HD FREE for 6 months
Dish Is Officially At My Home!
