VIP 622 and Seperator | SatelliteGuys.US
lacruz
83
I got a 622 about a year ago and the installer ran two seperate cables to the back of it, one for Satellite input #1 and the other for Sat input #2. I just got a 612, which is also a dual tuner, installed in another room. When the tech installed the 612, he used only one incoming cable and a DP Plus Seperator to then run two cables from it into the back of the 612. Can I buy a Seperator and do the same setup with my 622? Thanks for all replies...
I got a 622 about a year and the installer ran two seperate cables to the back of it, one for Satellite input #1 and the other for Sat input #2. I just had a 612, which is also a duel tuner, installed in another room. When the tech installed the 612, her used only one incoming cable and a DP Plus Seperator to then run two cables from it into the back of the 612. Can I buy a Seperator and do the same setup with my 622? Thanks for all replies...
Yes.
Receiver questions
when are mpeg 2 hd going mpeg 4 again?
